GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
If these are not the instructions, then add a comment with details. Don't downvote a free answer, that offers to help further, without posting feedback that helps the fixya community. Otherwise you should pay for the same answer and then explain why you don't want to pay.
