SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
SOURCE: unable to access scan folder
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
SOURCE: Toshiba e studio 232 is showing misfeed and
check the registration sensor for broken or dirty the registration sensor is on the transfer and seperation cover
