The problem is that if you ever use the memory stick on other camera besides the Sony DSC-F707 or format the memory stick on a computer instead of using the camera's format feature, then you will experience the "Memory Stick Error C:13:01" problem.
Here's the solution that finally will solve your issue. Take any lead pencil. Take the eraser and rub it on the gold contacts on the memory stick as if you are erasing writing on paper.
Do this for about 30 seconds or more until you get all the gold contacts. Put the stick in the camera, switch to 'Setup', then turn the camera on. The 'C:13:01' error will automatically disappear. At this point, quickly format the memory stick using the camera's format feature.
CAUTION: NEVER FORMAT YOUR MEMORY STICK ON OTHER CAMERAS, USING A COMPUTER WITH A MEMORY STICK READER OR USING WINDOWS XP WITH A USB CABLE PLUGGED TO THE CAMERA. IT DOESN'T WORK. FORMAT YOUR MEMORY STICK USING THE CAMERA'S BUILT IN FUNCTION ONLY.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
