GE XL1800 1100 Watts Microwave Oven Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My microwave stopped heating anything up last night and makes a funny noise while it is running. It clearly has power, but just does not heat anything up. What could this be and what would this repair cost approximately? Thanks!
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Feb 25, 2011
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10842655
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Sharp convection oven model R-980A stops randomly at .01 1.01 etc either microwaving or convection cant work it out
hi,
sounds like the control board. a bad solder. they cost 350.00 so your best bet is to try and disassemble and look for the bad solder joint on the control board, you could possibly take it to your local tv repair shop. here a link to the part. theres two boards one is power supply noise filter and logic. inspect both, make sure you stay clear of the HV red power lines running to capacitor magnetron, use a screwdriver and discharge the capacitor to frame before you start
jm
Sharp R980A R980A CONTROL CPWBFA753WRK0 Microwave Not Heating
Microwave not heating
The cause could be a defective magnetron, or inverter board, 7 years or less, or possibily the keypad control.
3helpful
2answers
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
I have a Sharp Carousel R-590 microwave that is about 10 years old. I fixed popcorn last night and after it stopped I added 30 seconds. It appeared to run but with a different and louder noise. However,...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps
Our kenmore microwave stop heating.. Everything works well but it just stop heating last night after l cleaned it.. did I do anything to it??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
78g
1helpful
2answers
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Microwave not heating and countdown lasts 20 seconds before stopping. put food in and start as normally do then it stops. Microwave is the genius 1200w.
It sounds like it is the "magnetron" has given up. In any Microwave there is a device called magnetron. This is the device which radiates microwave to heat up anything inside for set time.
Before the device gives up most of the time usually the microwave makes little bit of loud noise. Usually it happens when there is abnormal power.
Remedy: Any qualified technician should be able to replace it. The spare is available from the service centre of the manufacturer. In most cases spare is expensive and it is better off to buy another one.
Not heating
If the maggie went it's very plasible that it took out the Cap and/or HV diode with it.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
