Sony SVO-5800 VHS/S-VHS playback VCR Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need parts! Buttons broken on front face. SVO-5800P
Grubhead
Level 3:
  • Sony Master 5,755 Answers
  • Posted on Dec 03, 2010
 Grubhead
Sony Master
Level 3:
Answers
5755
Questions
Helped
1662185
Points
11417
Are they them that you press plastic with your finger and it pushes on a contact switch? If they are you can get away with just melting the plastic back in place with a soldering iron. You will need to remove the pannel to do this and melt from the back.
I have a 1984 svo mustang.on driver side under hood.i have.broken wires
Sorry I would need to see them to have any idea what they are for.
2answers
86 nustang svo, clutch is "engaed" even when you
Dearest gentlepersons please help on car panel it said stop engine car over heatting
1helpful
The front top cover over the face of the R-1611 is broken
The service manuals you'll need to refer to are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
1helpful
The printer carriage is jammed
hi first of all open the front cover of the printer and try to move the carriage mannualy by your hand while the printer is on now if the carriage is moving freely look if you see any obstacle or any broken part in the carriage rod .... clean the carriage rod with a soft cloth and then remove the in cartridges and close the front cover now while the printer is power on press and hold # and 6 and unplug the power cable while pressing the buttons and then wait for 5 sec and then plug the power cable back and now relese the buttons
wait for the printer to initialize now power on the printer and then wait for the message to insert the ink cartridge insert the ink and see if this works
if you still face the same error then it means its not a firmware error its a hardware malfunction problem and the device needs service
if you face any other problem while following the steps do let us know
Built-In Oven Buttons Stop Working
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
Email me for some pictures:
[email protected]
Recorder shuts off after 30 minutes of recording
it might have a timer set on it.. see if it is.
44helpful
5answers
I cannot open my compaq evo d51s, any ideas? BEWARE 1-800-975-0148 IS SPAM ON THIS WEBSITE
I just removed one of these cases.
The silver face-plate is attached to the cover that you wish to remove. The black plastic just below the silver is a part of the base.
  • With the face of the computer towards you, place your thumbs on the black plastic below the face-plate.
  • Use your fingers to press into the side-buttons.
  • Using your thumbs to push against the base, pull the cover towards you.
Inside buttons do not function at all.
The problem with you radio is the ribbon cable,this part connects the face to the main board.you get it from pacparts.com
parts number is 168795211
you can try to replace it by you own,just becareful with the front button because they may fall dow when you open the face.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
