Hello, Your laptop has no sound because you lost the sound driver or haven't yet installed it yet. Use this link below to download the sound driver, then run the file after download. It should be able to give you sound. http://driverscollection.com/?file_cid=39977724105e2f8a41252fdf59c Dont forget to rate my solution to show if it worked for you. Just vote for it.
You need to install the audio driver and other device drivers after installing Windows.
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Find the sound card, reinstall or update the driver. HP drivers can be found on the HP support site! Goodluck!
SOURCE: how to have access to the processor fan for hp pavilion dv5000
I found the Service Manual of the Notebook which contains the procedure about how to remove each and every component of your Notebook and below is the link to access the same :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Best way is to copy the entire link and paste it in the address bar of a new web browser and press enter to open the link.
Hope this is helpful...
SOURCE: My laptop (HP Pavilion DV5000) shuts down in the
Go into Control Panel and change the power settings so it never hibernates or dims screen.
