I have a Pioneer car stereo that keeps blowing the fuse that controls the right rear speaker. Also, when I turn my vehicle to the right, the entire radio goes out, then comes back on. Can you help me?
You have a short on the right side of the vehicle, you mention a fuse to the right channel speaker keeps blowing which tells me that either the speaker is blown or the wire running to it from the deck is touching metal somewhere. Check the wiring, or install a different speaker and see if it takes care of the problem. When you turn right the system goes off then back on tells me that there's a short. Check all of your stereo related wiring.
I also have this problem also so i took it apart with my dads mig welder and smeared peanut butter and bacon grease all over my mother board and it didnt work so scratch that idea then i connected my ground to my battery cable and that seemed to do the trick a couple days then it started again so i put a 0 gage wiring harness and it helped and my dad a reeetard and that he hates me .
i have a similar problem, except the fuse that keeps blowing out is in my amp/sub. ive taken my deck back apart and now need further explenation.
thank you
