Using to much detergent will make the washer stinky,also it will eat at the spider gear in the back of the tub and when that happens it's new washer time,it costs 450 to 500 dollars just for the part,you should be using 1/4 cup of detergent and it should be H.E. detergent,when the wash is done you should wipe down the boot seal,spred it open and clean out the bottom part and wipe it down till it's dry.also you could have debris stuck in the filter in the pump.remove the bottom panel,unscrew the middle part of the pump and whatever is in the filter clean it out,it gets loaded with coins,lint and everything else that gets left in the clothing and then it gets a detergent buildup and my god does it stink,you would think the detergent wouldn't smell but it does,so wipe down the boot,use less detergent and every 4 to 6 months clean out the pump and you should be fine,let me know how you make out,run the washer with nothing in it,if you see suds in there this is your problem,after you clean out the pump and run it with nothing in it use the tablets again and go from there,good luck
