The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes: Basic Beep Codes for ABIT AWARD BIOS Motherboards
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM isn't inserted correctly
Short(Beep) continuous POWER supply has a problem
A two-tone siren, generally caused by overheating or out of specification voltages
Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too. 1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem. 2. 1beep - board is working fine. 3. One long beep then it shuts down - cpu problem, your processor is not working or missing. 4. 1short beep - system boots normally 5. 2short beeps - CMOS setting error. 6. 1long 1short beep - dram error 7. 1long 2 short beep - video card or monitor not connected 8. 1long 3 short beep - keyboard error. 9. 1long 9short beep - ROM error 10. Long beep - memory card is missing or not connected 11. Short beep - power supply error 12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Trying your peripherals one at the time is the way to find your problem, Memory first - one beep is good, If your mb has onboard video use it first. if not check the settings in the BIOS may be a shared memory that is not set right. Make sure your memory is computable ck one stick at the time.
Beep by motherboard are due to hardware problems. It's either the hardware is problem or it's not properly connected. Try check your RAM or graphic card weather it is fix properly. And also try to check your jumper connector. Sometimes one of the jumper connector may be damage and create the beep sound.
Does this alarm go off while playing Flight Simulator 2004?
Please include your operating system Ex: Win XP home, PRo . How much memory is in your system? How many dimms, 1,2,3,4?
What video card do you use, Ex: PCIE ATI Radeon 256Mb 9500?
Can you describe the alarm a bit better. A long beep with short beep, repeating untill the system shuts off?
Answer these question so I can narrow down the what may be troubling your Pc.
