Baird 47 code for sky remote
I have a baird 47 inch hd tv, model J047.does anyone have the code for the sky remote?
Need a replacement control tried all codes for sky remote https://electrohelponline.blogspot.ca/ http://www.remotecodelist.com/ Codes for Universal Remotes How to Program Universal Remote
137 221 371 218 220 101 236 100 033 245
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
my tv will not switch on the small red light comes on but nothing else
is it time to get another tv
my tv will not switch on the red light comes but nothing else is it time to get another one
