SOURCE: Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
SOURCE: LG LD65E humidity variance
Is the compressor running or is it just the fan? If its just the fan it is because it is cycling the air and it uses that air flow to check the humidity in the air. If the fan runs non-stop and the compressor does not turn on or the fan does not shut off there is a problem with this unit and you will need to replace it. Since it is brand new you should still be able to return it to the store.
SOURCE: no water in the bucket
You most likely have a freon leak, or the compressor is not running. When the machine first turns on you should be able to see if the compressor is running or if it is just the fan. If the compressor is not running it does have a start devise and a relay on it that can be replaced. If the compressor is bad, most units have a 5 year warranty on the compressor, so contact the manufacturer for warranty service. If the compressor is running you have a freon leak, and it would need to be found, repaired and the freon replaced. This is a large repair, estimated charge for a leak repair would be around $149.99 The reason is the long time it takes to find the leak, and all the parts needed. Drier, valve, freon, etc.. Good luck, and I hope it is only the relay. You can get those relitively inexpencively. 3 in 1 kits are also good for a hard to start compressor. They give the compressor a little more kick to start it. They are about $28.00 and easy to install once you are to the compressor. I hope this will FixYa.
Mike
SOURCE: "Lo" reading at humidity setting
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end. if this helps please rate me.
SOURCE: fan run continously, but produces very little
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Hey Art Miner, thank you for your post!
I understand that your dehumidifier is not operating properly. You should put it on a continuous drain mode to see if it will continue to pull moisture. Could you please provide feedback to what your appliance is doing once set to a continuous drain? -Matt
