The best solution is to format your disk.....I too faced the same problem once formatting seems the only solution.....it happens mainly due to virus........plz like if helped
)In the Start Menu click on Run. Type, without the quotes, "regsvr32jscript.dll" and then click OK. Next, repeat the process but this time type inthe Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are usingWindows Vista temporarily disable the User Account Control (UAC). You caneasily turn it back on. On the Control Panel (Category View) choose UserAccounts and Family Safety, next choose User Accounts, and then click Turn UserAccount Control on or off.
3)If the above does not fix your problem and you are using Windows XP, you canupdate your Windows Script to version 5.7. In my experience helping others,this is the step that has helped the most people. Exit all browser windows andchat programs including Yahoo Messenger before installing. run registry cleanerreginout cleaner to easily fix it
The first thing to check is to make sure you have scripting enabled in Internet Explorer. Internet Explorer is integrated into Yahoo Messenger so things that go wrong with IE can affect Yahoo Messenger. Here is the yahoo help page about that: http://help.yahoo.com/l/us/yahoo/messeng...
2) In the Start Menu click on Run. Type, without the quotes, "regsvr32 jscript.dll" and then click OK. Next, repeat the process but this time type in the Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are using Windows Vista temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
3) If the above does not fix your problem and you are using Windows XP, you can update your Windows Script to version 5.7. In my experience helping others, this is the step that has helped the most people. Exit all browser windows and chat programs including Yahoo Messenger before installing. run registry cleaner reginout to easily fix it
go too www.yahoo.com, on the left pane, locate the yahoo messanger link and download the yahoo messanger application. After the download run the application and follow the instruction to complete it.
Install any firewall client.. Windows Xp service pack 2 and vista has this inbuilt.. Then configure your firewall to block accepting connections by this software...
First please uninstall the yahoo and install the latest version of yahoo messenger from net. Next please follow the step by step troubleshooting if you are still facing the issue:
Instructions
Step 1:Reduce echoes by using a headset instead of speakers and a microphone. Place the microphone farther away from the speakers, if possible. Adjust the volume of the speakers and the microphone.
Step 2:Verify your Internet connection speed if your friend's voice sounds choppy. The computer modem speed must be 56K or higher in order to send voices or sounds.
Step 3:Go to "Actions" and "Call Setup" in Yahoo! Messenger if you can't hear, or your friend can't hear you. Test the sound by following the instructions that proceed call setup.
Step 4:Click on the speaker icon in the lower right corner of your computer screen if you want to test the sound manually. Uncheck "Mute," if necessary, and make sure sound levels are above 50 percent.
Step 5:Pick "Preferences" in Yahoo! Messenger if you have trouble with connecting to the voice server. Choose "Connection," then select "No Proxies." Log in to Messenger again to check the voice server.
Tips & Warnings
Follow your computer system's instructions for checking or modifying the server's TCP ports. Ports numbered 5050, 443 or 80 must be open for the voice features to work.
Install the audio codec software that comes with Windows. PC calls and voice chat require that the software is enabled on your computer.
If your Admin blocked your yahoo messenger, I suggest you to use it by yahoo web messenger, goto: http://us.ard.yahoo.com/SIG=15sm4oam0/M=650008.12554200.13293944.12166001/D=pager/S=2022919009:HEAD9/Y=YAHOO/EXP=1239239978/L=SNb8BkSO5syeNwd6SOlEShIFXX4ICkndMQoABthR/B=o69KCESO5.g-/J=1239232778460647/K=ZO9FKfg8L9C4VcUsmpeiLQ/A=5498331/R=10/SIG=10uacnjgh/*http://www.yahoo.com/bin/set
Sign in and enjoy it!
if you are using Win Me,Winxp or Vista there is a option called system restore in Accessories System tools.Click system restore ,you can see the dates in one side.Select date which you have installed yahooMessenger and restore it to the previous date.No need to be scared it will not change your personal data.
Can you just say wht problem u r facing in Yahoo9?
