Microsoft Windows Vista Ultimate Edition Logo
Posted on Dec 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows has stopped this device because it has reported problems. (Code 43). THis error message is coming while connecting bluetooth dongle to my toshiba laptop windows 7 64bit plateform
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on Dec 02, 2010
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
716606
Points
6960
Try this, diconnect Laptop from power source ie Remove the battery. Unplug your bluetooth dongle from the Laptop. Reinsert the battery back to your laptop after about 30 sec. Restart your laptop & insert the dongle.
Hope it fix your problems.
Panasonic kx f612 code 43 error
Windows has stopped this device because it has reported problems (Code 43).
Code 43 can be summarized in two words: driver problem.
I can't help you any more without knowing which Windows version you are using, but the Panasonic website is
http://panasonic.net/pcc/support/bfax/
1helpful
My Plantronics C420-M is not recognized
How To Fix Error Code 43 Windows has stopped this device because it has...
If Windows Device Manager is giving a code 43, this means the hardware is reporting something wrong when trying to connect. I'd do the following (and also check the attatched link for reference ;-) )
  • Unplugging the headset, restarting the computer, then plugging the headset back in.
  • Make sure the USB connector on your headset (and the USB port you're putting it in) is undamaged, and not dirty.
  • Try connecting the headset to another USB port, and another computer to see if you're able to reproduce the issue there (if not- it may just be the USB port(s) on your computer that you're plugging the headset into that's failing.
If all else fails, it may be time to purchase a new headset ;-)
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
2answers
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
I've installed a darfon bluetooth radio into my hp compaq 6715B laptop. I've also reinstalled the integrated wireless utility thing. Its not working, device manager states "windows had to disable the...
Code 43 Windows has stopped this device because it has reported problems. (Code 43)Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner. For more information about how to diagnose the problem, see the hardware documentation.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
