Hello !
I know that want have some fun using the deck gun too. so flow this instruction below :
Install info:
As with all my mods, this mod is jsgme ready and it includes a read me file. Open the downloaded zip file and then open the mod folder.
Inside the read me will tell you about the mod and the folder next to it is the actual mod itself. that is the folder you need to put into jsgme.
if the mod has more than one version then just choose the one you wish to use or the one that was made for your game version.
download link :
http://www.gamefront.com/files/13911816/Webster_s_Upgraded_Deck_Gun_for_v1_4information About this Mod :
This mod will increase the damage caused only by your deck gun shells by increasing the shells effective strength (explosive impact) and i also increased all the shell speeds up about 20% from where they were originally set at so you should have a little less droop or downward angle to your shells.
shell reload times are now set at about 2 seconds for faster firing rate, the original stock setting was set at 4 seconds.
i also gave you a much larger ammo reserve so you wont be running out of ammo during your missions.
i have also increased all of the AA guns ammo reserves and reload times were cut in half for them but i left the fire power strength of them alone.
if any conflicts show up with other mods then just install this mod last and overwrite any files.
Good luck
Khalid
