Hi, seems that the red cartridge finished. replace the color cartridge.
Tips & Tricks For HP Printer Ink Refill Kits
Brand
new printer ink cartridges cost a considerable amount of money in
general, and while printer ink cartridges from Hewlett-Packard can be
said to be more affordable than most, they are still a little bit
expensive. Thus, it makes sense for the average computer user to give
using HP printer ink refill kits a good thought.
Buying and using HP printer ink refill kits
do translate to savings for the average computer user. However, the
downside of this is that if these refill kits are used incorrectly, it
can lead to irreparable damage to the printer. This is particularly
applicable to HP printers because their printer ink cartridges are
designed to be part of the printer head.
To make the task of refilling printer ink cartridges using HP printer ink refill kits easy for the average computer user, here are a few tips and tricks.
1.
Always buy an HP printer ink refill kit that is specifically
manufactured for the particular model that you have. Each printer unit
requires a specific formulation of ink to function properly. Feeding
your HP printer with the wrong type of printer ink will permanently
damage your printer.
2. Never wait for your printer ink cartridge
to go bone dry before you refill it. Always watch out for signs that
the ink cartridge is running out of ink. If you wait too long, the
printer ink left inside the cartridge will clog the cartridge outlets
and damage it. Refilling a damaged ink cartridge will result at best in
bad print quality and at worse in irreparable printer head damage. If
you are not sure if your printer ink cartridge is empty, print a test
page.
3. Make sure that you follow the instructions on your HP
printer ink refill kit to the letter. If you do not follow the
instructions carefully, you will only end up with a damaged cartridge,
or worse, a damaged printer head.
4. In filling a colored printer
ink cartridge, be certain that you fill the cartridge chamber with the
correct color of ink. Failing to do this will result in skewed printing
results.
5. No one wants to get messed up while refilling an ink
cartridge with a refill kit, so always line your workplace with cloth
before you begin. Cloth will absorb the ink and keep it from seeping
onto the surface of your workplace.
6. Got ink on your hands while refilling your printer ink cartridge?
Do not worry about it. To remove ink stains from your hands, just
wash it first with soap and water to get the excess oil of the ink off
your skin. Follow it with a wash of mild bleach mixed with water. And
then, wash your hands again with soap and water to get the bleach off.
Using
HP printer ink refill kits are very handy and can result in
considerable savings. But here is a caveat for you, though: If your
printer is still under warranty, you will lose your warranty in case it
is damaged by printer ink from the refill kit. Also, you can only
refill an HP printer ink cartridge once or twice because the risk of
ruining the printer gets too high. So, be careful in your use of HP
printer ink refill kits.
You can use the below link to for help..
hpcartridgerefills.com/tips-how-to-fix-a-troubled-printer-cartridge-picture-tutorial/
Hope it helps..
Thanks for using fixya........
If replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
