Woods Outdoor Lighting Timer Logo
Posted on Dec 01, 2010
How do I set the Woods N1506 timer? - Woods Outdoor Lighting Timer
A
Anonymous
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
5 Related Answers
A
Anonymous
  • Posted on Nov 24, 2010
SOURCE: How do I set my
According to another fixya answer posted December 4 2009:
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
A
Anonymous
  • Posted on Nov 29, 2010
SOURCE: How do I set my woods model N1506 outdoor timer
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
A
Anonymous
SOURCE: I need the user guide for a Woods Outdoor Timer
N1502 manual:
http://waterheatertimer.org/pdf/Woods-49103-N1502-manual.pdf
N1506 manual:
N1506 written instructions
http://www.fixya.com/support/t6964404-set
A
Anonymous
  • Posted on Dec 01, 2010
SOURCE: Model N1506, I need Operation instructions for
N1505 timer manual:
Anonymous
  • 8197 Answers
  • Posted on Jan 23, 2011
You can get the manual on the link below.
052-8835-2 Noma Block heater timer
Copy following link to identify various timers and download possible manual. Timer was originally made by Intermatic.
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
http://waterheatertimer.org/pdf/Intermatic-HB65R-timer.pdf
N1506 is 2-button timer and is called a block-heater timer.
This timer has 1 year limited warranty through Coleman.
http://www.colemancable.com/contact-us/technical-support/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a Noma timer Model N1506.I do not have a manual to know how to operate or set the time. Need help,please. Thanks, Eric [email protected]
Open following link to identify timer with manual:
Manual for Intermatic/Noma 1506
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
8helpful
2answers
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
2helpful
I have a Noma outdoor timer at the top it has time PM then a button that says time & one says number on back 1915774 & 0550 Mode model number n1506 how do I set it to come on and off re: Xmas...
Woods 49122/N1506 manual.
Your description sounds similar to timer shown in manual.
If this is not your timer:
Woods makes a lot of timers with more than 1 number depending on who packages and sells timer.
Here's a link to Woods timers that might help you identify:
Top Woods Hardware & Accessories Experts
vince
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
