Hi.
On order to make an external hard drive readable from a dvd player you need to reformat the hard drive to fat32 format. Most DVD players are only able to read drives formatted in the FAT32 system,
To format the ext hard drive to Fat32 you will need to connect it to your computer first to carry out the formatting.
1) Click "Start" then "Run"
2) Type "CMD" into the text box, then press "Enter."
3) Type "Format /FS:FAT32 X:" into the command prompt, replacing the letter "X" with the actual drive letter of your USB hard drive. If you do not know the drive letter of your hard drive, open "My Computer" and look under "Devices with removable storage." BE SURE YOU HAVE SELECTED THE CORRECT DRIVE LETTER TO FORMAT. Then press "Enter".
4) Press "Y" when you have identified the correct drive and you are ready to format the hard drive. All data present on the drive will be erased once it has been formatted. The drive will now be formatted to FAT 32
5) Load the films onto the USB hard drive. Be aware FAT32 file system cannot support files larger than four gigabytes.
6) Connect the ext hard drive to your DVD player via usb and select "USB Device" or it may be labelled as external device. Your DVD player should recognise the device and play the films.
Thanks for using FixYa. Please do leave a vote for the solution.
No, the external hard drive isn't compatible to your Samsung: that USB connector has been designed to accept only USB memory sticks that are 16 GB or less. There is nothing that can be done to make it accept an 1.5 TB hard disk.
i have used a different hard drive on it just not one as big what about on a ps3 then?
will it work on play station 3
will it work on playstation 3
will my hard drive work if i plug it into the usb on my playstation 3
