Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with full HD receiver ?) What that means tehnicaly?, price ?? Thanks for your answer. Janko Zavernik
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Dec 01, 2010
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2820996
Points
26282
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
1helpful
The Bravia menu comes up across my screen. It will go off when I hit any button on the remote & then come back on. the model # is KDL-32EX301. How do I get it to go away?
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
Invertor board for sony bravia kdl-40V5810 needs replacement
Contact the authorized service center for Sony, to buy a genuine inverter board. If you wish to get some details, check the site linked here. Pull up older posts.
1helpful
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
Which video format is used for usb to see movie in sony bravia
hi,
your tv will support the following video formats
MPEG-I or MPEG-II
ok
2answers
I have 32" SONY BRAVIA. But can not watch full
MPEG-I or MPEG-II Assuming you are talking about playback by USB
Alex
2helpful
Tv sudenly turns off and then on several times, eventualy lights up again, but goes on cliking for a while . (lcd sony bravia9
Well these TVs have a very large quadricle processor which can sometimes over load. My suggestion would be:
1. Watch ****
2. Watch more ****.
3. Put it in your back yard.
4. Take a sledge hammer
5. Beat the **** out of it.
6. Tell your mom I don\'t want to have *** with her and beat the **** out of her too.
2helpful
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
1helpful
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
