EliteGroup P4VXASD2 Motherboard Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows failed to load because the firmware (BIOS) is not ACPI compatible
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Dec 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
528149
Points
7608
Please change the cbos battrey and set the bios optimize default
F10>yes.
hope it will help tou
dont forgate to vote me
Nuno Pinho
Level 2:
Scholar:
  • Expert 105 Answers
Nuno Pinho
Expert
Level 2:
Scholar:
Answers
105
Questions
0
Helped
23871
Points
271
Hi.
That happens when you are connected to the internet and somehow a wrong update overwrites your bios. If your computer has a floppy disk, go to your Motherboards manufacturers website, download your Bios for your Motherboard Model in the Support button, get instructions first. Follow all the instructions. After download, unzip to your floppy disk. Reboot computer from floppy disk and run the setup as instructed in the website. Flash your bios.. Your problems with ACPI will be solved.
If that dosnt work, restart the computer. Press DEL or F2 to enter Bios setup.
Go to settings and Enable ACPI compliant. save changes and restart the computer.
If that fails let me know so that I can prepare correct Bios Setup for your model.
Good luck, and hope to hear from you soon.
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
1helpful
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
I received a message that said my system was not ACPI compliant. I have no idea what that message is talking about. Can you help?
Whatever your doing, is not compatible with the current BIOS standard which in today's computer world is ACPI (Advanced Configuration and Poer Interface) post Windows 2000. Older BIOS systems versions used APM (Advanced Power Management). You must be trying to put in different hardware or something on your motherboard (computer) that is not compatible or functioning properly.
1helpful
I load my computer and it just says my bios is not compatable with my acpi cpmliant what can i do?
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.
Other possible causes that have been - memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.
Blue screen ACPI.sys on install (brand new system, first install)
my client office one system working windows , when booting time displaying blue screen error" acpi.sys " . and then continusly system restart., but, i was maked the first and second repair, still now i didn't got solution for this problem. please help me. and also i want need ur help for blue screeen error.
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
2answers
Acpi bios
Hi suleman_indi, I'm guessing you have a question about the D845GVSR motherboard. If your question refers to the bios setting for ACPI. Disable it until windows has been updated to SP2. Enter your bios & enable the ACPI. Should be fine once windows has been updated. Click on this link to load Intel's site for the Intel D845GVSR motherboard.
http://downloadcenter.intel.com/Product_Search.aspx?Prod_nm=+D845GVSR&lang=eng&MissingSearchTxt=Please+enter+a+valid+product+name%2C+filename+or+product+ID+%23.&x=21&y=5
If you find you need more information, feel free to update your question.
Mike
Hang
Hello there what i think may have been obvious to you. So i will tell you what i think is wrong. You see vista is a very high software and requires motherboards that are top of their game i think you should get you motherboard upgraded to a point where vista rates it to total of 2.5 then everything should run ok. if you want to ask for further assistance write back to this post and i will be ready to assist you.
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
4answers
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
