1. If you need more help come back.Post /
thumbs / testimonial are
welcome!
Open Network Connections
2.
Right-click Wireless Network Connection, and then click Properties.
3.
On the Wireless Networks tab, do one of the following:
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings
check box. This check box is selected by default. For information about
what happens when you enable automatic wireless network configuration,
see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties,
specify the wireless network key (Wired Equivalent Privacy) settings,
or, if the network key is automatically provided for you (for example,
the key is stored on the wireless network adapter given to you by your
administrator), select the The key is provided for me automatically
check box. If you are unsure about whether a network key is needed or
which settings you need to enter, contact your network administrator or
the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Min System Requirements for Tom Tom Navigator are as below:-
Windows 2000, XP, Vista, or Windows 7 (newest servicepacks required)
Pentium III or higher
256 MB RAM, 512 recommended
Internet connection (Broadband - DSL/cable/LAN) for downloading updates, maps or services
The TomTom HOME software is a 20MB download requiring 50MB of disk space when installed
For NAVIGATOR 6 devices, the system requirements for Windows are:
Windows XP, 2000, Vista or Windows 7 (newest servicepacks required)
500 MHz processor or better
128 MB RAM
Internet connection (preferably broadband - DSL/Cable/LAN) for downloading updates maps or services
Internet Explorer version 5.0 or higher
Please note that the following MOBILE & NAVIGATOR versions are not supported by TomTom HOME:
MOBILE
MOBILE 5
NAVIGATOR 1
NAVIGATOR 2
NAVIGATOR 3
NAVIGATOR 2004
NAVIGATOR 5
