I have the JBL Eon 515 Speakers.. I found a blown fuse in the amp, replaced it with a fuse from the speaker that was working correctly, and switched the power cords and it still wont come on. Where do I go from here? Theres not a lot of troubleshooting information over the www. Help please??
I have a pair of Eon 515s. One would not power on. Sent it to the factory and they fixed it. Now the other won't power on. WTF???I have a pair of Eon 515s. One would not power on. Sent it to the factory and they fixed it. Now the other won't power on. WTF???
You can't post conmments that contain an email address.
Several ways. Easiest way is to just hook up mic to speaker via XLR and make sure on jbl speaker switch is set to Mic not Line. ( for volume ). Ideally you would hook mic to a console ( mixer ) and come out of mixers main out (l/r) to 2 separate jbl speakers ( being powered no amp is necessary ) for stereo!
If you can watch the fuse kind of twitch. Most likely you have somthing shorted in your output amps. ( the ones on the heatsink underneath PCB) you'll probolly need a tech for this one to change out the transistors. Still under warranty?
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
