You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
SOURCE: belt manual
Here is the manual. on page 17 tells you how to change.
http://dl.owneriq.net/2/23cae7f7-686f-47c1-8efe-3a106fffcd50.pdf
Good Luck and Please Rate FixYa!
SOURCE: bissell proheat model 8910 water will not come
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
