It sounds like the charger is the problem. The battery and the phone seem to be ok since you can use the usb cable to charge the phone. I would check the charger to see if there is any visible damage. You can also see if a friend has the same connector (many new phones should due to the EU ruling last year) and check their charger with your phone and their phone with your charger to verify the charger is faulty, but replacing the charger would probably the best solution. Depending on how long you have had the phone, Nokia might cover the charger under the warranty, but I don't seem to be able to find that information.
