The projector will not turn on as the lamp/cover light is flashing. I have replaced the bulb and the lamp cover and air filter cover are both closed properly. Any ideas ?
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Thx so much, the switch is not in the lamp area it is on the silver bottom where the silver cover sets. Found it finally Thank you. Works in time for the conference!!
It was just where you described Gery THANK YOU!!!!!!
I have a similar problem. I hit the power button, I can hear the fans come on, and after about a minute or so the power shuts off. Then other times I hit the pwer button and it comes on. I have also changed out the filter, bulb and found and secured the sensor. I will look again to make sure Im securing the correct sensor.
Tried the above and still a no go..
