Hi my bosch classix 1200 will only add water and drain, no actual wash cycle or spin. Can hear lots of clicks as the program is run but no movement in the drum.
Thanks Bill
I can think of a few things to try.
1) Check for a blockage in any of the pipes or if it has one the filter
2) Brushes might be worn on the motor
3)A faulty module. The only way to check this last one is to replace with a known working one.
Good luck.
The brushes have worn fiddly to replace but local engnr charge no more than £50 good machine worth repairing
Well. check for limescale in the back. if there isnt any there then call a mechanic ^_^
