Desa International GWRP16 16,000BTU LP Gas Heater Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Glo-Warm "DESA GWRP16" LP wall heater.
Paul Carew
Level 3:
  • Desa Interna... Master 3,808 Answers
  • Posted on Nov 30, 2010
Paul Carew
Level 3:
Answers
3808
Questions
Helped
1299281
Points
10526
Sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
I bought a new Desa heater that still had the tags on it from a private owner, never got it hooked up. It is the infrared gas heater GWRP16, GWRN18, manual I have to go with it. It did not come with a...
Yes, click on the following link and it will take you to Master Distributors. They stock DESA/Vanguard parts. Sorry that you'll have to pay for something that was supposed to come standard with the heater. http://www.vanguardheaters.com/
Be sure you have your Model Number handy when ordering.
Glo warm model FA3 burner one and two flame is too high #3 is fine
The higher flame on those 2 burners may be by rusted out. Of course this depends on how old the heater is and how well it has been annually maintained. Unfortunately, DESA International is no longer in business, but some parts are still available. You just have to search the internet for them.
I need a pressure regulator for my glo warm heater where can I get one
You can get most any pressure regulator from www.grainger.com
heatman101
1helpful
My glo-warm wall mount heater pilot light will not light. I tried the ignitor, saw blue spark , and nothing. I also tried using a lighter, I got it to light barely once and that was it. I can't smell any...
Without the model number of the heater it is hard to give an accurate answer but I will give you some suggestions.
I would start with cleaning the pilot ODS assembly.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
I would check the regulator on the heater...if it is propane these gas get raw gases in the regulator and cause the unit not to pressure up correctly.
Give these items a try first before replacing any parts.
Thanks
M Cramer
www.allpartsinc.com
1helpful
Can I modify my model #RSE5LP Glo-Warm heater from a ventless to a vented one?
Because the heater you have is rated by Underwriters Laboratory (UL) it cannot be modified. Sorry.
Glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
