Posted on Nov 29, 2010
Turn power on and the standby light just flashes on my sharp xr-11xc. What am I doing wrong?
5 Related Answers
Anonymous
  • 563 Answers
  • Posted on May 21, 2008
SOURCE: lamp replacement
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
projdoc
jasbo
  • 2239 Answers
  • Posted on Jul 23, 2009
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
projdoc
jasbo
  • 2239 Answers
  • Posted on Nov 24, 2009
SOURCE: i just changed the bulb in my sharp xr-11xc. it
reset the lamp timer. hold down the menu, down arrow, and enter buttons, then press power.
projdoc
jasbo
  • 2239 Answers
  • Posted on Dec 04, 2009
SOURCE: sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
projdoc
jasbo
  • 2239 Answers
  • Posted on Jan 27, 2010
SOURCE: i just replaced the lamp in my xr-11xc sharp
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
2answers
My projector xr-11xc does not power on after it has been plugged in
Please check the internal fuse. It should be right underneath the power plug port. If it's broken, then buy a new one.
Lamp issues
Look at the ballast module. It controls the lamp operation
3helpful
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
1helpful
2answers
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp...
3helpful
I just changed the bulb in my sharp xr-11xc. it worked fine till i turned it off and now its not working again
1helpful
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
DO NOT HAVE A USER MANUAL- AHARP XR-11XC MULTIMEDIA DLP
You can download user manual of Sharp XR-11XC from HERE for free as website will ask you any of your email address only.
User manual has all info about this unit.
Lamp replacement
Hi traks137
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
