Question about Timex Expedition 40141 Wristwatch
How to change a timex battery - Timex Expedition 40141 Wristwatch
    Brigadier General:
  • 8,546 Answers
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Posted on Feb 23, 2011
6ya staff
SOURCE:
How do you take the back off a watch?
The easiest way it to take your Timex watch to a jeweler who will demonstrate how to remove the back and may be persuaded to install a replacement battery - all for a reasonable sum.
Feb 20, 2018 | Timex Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How to change battery on timex t2n793
Expect for buying yourself a 'case holder' the general instructions are here and mind your fingers !!!!
http://www.mademan.com/mm/how-change-timex-watch-battery.html
Sep 03, 2014 | Timex T2N795 Watch
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
How do you replace battery
only timex watch technician is changing the battery of a timex perpetual calendar because the date must be calibrated so that it works properly again...
Jan 11, 2013 | Timex 2G561 100 Meter Watch
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
Timex ironman 100 lap battery replacement
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area, the tools you"d need, time and the risk in ruinning your watch doesn"t out way the small cost of the shop changing the battery.
May 20, 2010 | Timex Sports Ironman Triathlon 100-Lap...
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Jun 01, 2009 | Timex Watches
Timex Expedition 40141 Wristwatch Logo
261 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
pacdave
Are you a Timex Watch Expert? Answer questions, earn points and help others
