Computers & Internet Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will run forever but locked up. no startup
Anonymous
Level 3:
  • Master 374 Answers
  • Posted on Nov 29, 2010
Anonymous
Master
Level 3:
Answers
374
Questions
Helped
67467
Points
1230
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
My hp a 1410n desktop powers up but shuts down after five seconds
#1 on the list for this is shut down from over heat due to CPU fan not running or CPU overheat. Check to see if your CPU fan is turning on when your system is powering up. If its not.. thats your problem (get a new fan)... Even if it is it could mean the fan is not properly contacting the CPU with thermal paste. If this is the first time you\'ve powered the system up, your next step is to go out and get some thermal paste and put it under the CPU fan, if you\'ve been running the system and this problem just cropped up.. skip the thermal paste, its already there. #2 Next possibility is BIOs power settings are incompatible with your hardware. For example the frequency on the CPU is set higher then it can operate and its over heating. Some systems will automatically shut down and restart with default settings others you have to get into and set to default. can you get into BIOS? Can you reset your BIOS settings to defaults? Check your mother board manual. #3 A compenent is shorting out your system and needs to be replaced. Is the system posting prior to shutdown (beeping once on start up?) If its beeping more then once that means something else and you should read your manual. If its not beeping then its a short somewhere and you can bet you have a bad part in the system. To identify which part it is you can either disconnect things (RAM, Drives, vid card, PCI cards,ect) one at a time, attempting to start the system after each one or you can take everything but the bare bones out and try to start it. I usually take all the RAM out but one stick and start by testing them. Your RAM is the most likely place for a problem in this situation. #4 If you\'ve striped it down and it still can\'t get a boot (with no post beep). You need to replace the mother board.
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Toshiba Tecra M3 Laptop keeps freezing and shutting down, Can't even do Fresh Install on New Hard Disk Without Freezing, Have Replaced CPU Heatsink Compound.
What made you suspect the compund? You're probably right though. The fan has died or is too slow. The CPU and the video chip are what the fan is protecting. It might require a new CPU chip and fan. If it's the video chip, then a new mother board is in your future.
Good Luck
2answers
My hp pc seems to try to start on but then it shuts down immedia.
Hi there.
If its the CPU (processor fan) thats not working, it could well be the machine overheating and shutting down to prevent further damage to the machine, try another fan, if it spins up the CPU fan has gone and will need to be replaced.
If you have a working fan but it doesn't work on the motherboard, check the power supply unit as that could be faulty.
Good luck and thanks for using FixYa!!
2answers
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
1helpful
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
2helpful
2answers
Turns on, then shuts down before anything shows on monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Computer shuts down problem
When you take the cover off and start up, are all of the fans spinning? If the CPU fan doesn't spin, the system will shut down soon after starting to prevent over heating the CPU
Grand Canyon Tech
Grand Canyon Tech
