SOURCE: fic k7mnf-64 motherboard socket 462
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
SOURCE: Need Network adapter
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
SOURCE: need the photo of where
Please refer first to your motherboard manual to find where your power switch and reset pins are located. >>
emachines/manuals/K7MNF-64_manual.zip
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
SOURCE: I need a K7MNF-64 Motherboard 102732 manual. Can
http://www.brothersoft.com/downloads/computer-manuals.html this site will tell you how to use something http://www.easyhelpguide.com/manual/ASRock.html http://www.easyhelpguide.com/manual/index.html http://www.easyhelpguide.com/manual/index.html here are many manuals and guides on how to use things hope this helps you
you will have to type in the motherboard in the top search tab
