SOURCE: Nokia N95 wont display Log
Resetting to factory settings will probably sort it out. But you might loose the data stored on the phone. You'll find the reset in the menu, tools, settings.
I'm assuming that you switch your phone off sometimes, if you don't, try a restart first.
SOURCE: How to delete one entry from log NOKIA E63. I
FIRST YOU HAVE TO GO FILE MANAGER, THEN U CAN DELETE.
SOURCE: Please tell me , How to find the IMEI number for
On the phone keypad, press *#06# this will display the IMEI no. of the unit.
Hope this helps
SOURCE: on nokia 6500 slide contact name not displayed
Hello
The problem you are experiencing occurs when you store your contacts on your Sim card and the memory in use is your phone memory or vice versa
what you should do is this;
In your contacts settings copy your contacts into your phone memory and set your memory in use to phone memory
You wouldn't experience this problem anymore
best of luck
Testimonial: "thank you problem solved am very happy"
