Hello emg27
The machine has water inlet solenoids that are plastic cast into one part where you connect your hoses, H and C. If water does not enter the tub the level sensor will not close contacts sending a signal to start washing. So check water to this valve first, then you can remove the hoses from this solenoid and view the screen washers for build up of contaminates that may be preventing the water from entering, or the valve itself maybe malfuntioned. The solenoid is just a magnetic coil pickup that lifts a stopper internal of the valve. The unit is sold as a complete on piece w/both coils for H and C. The noise you hear may be the magnetic coil energized.
Good luck I hope this helps.
