Microwave Ovens Logo
Posted on Nov 28, 2010
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and food/beverage doesn't get hot). The following has worked for me and don't know if they are related: 1. I open the door and shut it again and restart the timer - works sometimes 2. Do a power reset - unplug the microwave and replug back after 1 min - works sometimes When it works, it works well. Why do I have this intermittent issue?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 21, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
308
Points
0
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
5 Related Answers
A
Anonymous
  • Posted on Jul 14, 2007
SOURCE: Microwave does not heat
Just had the same experience with the identical model. Removed the cover (a challenge because of the security screws), revealing valuable troubleshooting directions intended for an experienced technician. However, I think the info is well within the reach of a typical DIY person, does not require any dangerous power-on conditions. However, make sure that you discharge the HV capacitor before trouble shooting. In my case, it appears that the HV diode is open, have ordered a replacement on the internet for $3.18, easy to replace. Hope it works. Good luck.
Anonymous
  • 43 Answers
  • Posted on Feb 15, 2008
SOURCE: Emerson Model MWG9111SL Microwave not always working
Every thing works, but no heating and no noise. I am happy you had noticed that there was a difference in the "Noise". Some describe it as a vibration you can feel in the cabinet. The "Noise" is only present when the High Voltage Transformer is engaged. The "Noise" is a low Humm which The High Voltage Transformer emits. Without The High Voltage the unit will not Heat.
BECAUSE you say it heats Sometimes. I suspect a LOOSE CONNECTION between the Low Voltage (115v) and the Primary of The High Voltage Transformer. Could be a Solder Connection, or just a Loose Wire. Loose, not Open. If it were OPEN it would not "Cook" at anytime.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 16, 2008
SOURCE: MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Anonymous
  • 3 Answers
  • Posted on Jun 01, 2010
SOURCE: Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Anonymous
  • Posted on Nov 01, 2010
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Samsung MW82Y microwave acting strange.
Now you know why they were selling it, it doesn't work and needs dealer service!
https://www.fixya.com/support/r29874712-repairing_microwave_ovens
1helpful
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
2answers
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Our Magic Chef microwave timer counts down, but no longer cooks
Probably not because the timer works.Try the door switch.
2answers
GE Profile JE2160 - Just stopped working. Touch pad works, light goes on when door opens. When starting, timer counts down, can hear a relay click, but nothing (no fan, no turntable, no magnetron. Fuse...
Hi
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. You should check the internal door switches, the high voltage circuitry and the circuit board for this kind of problems. But for that you will need a certified technician to help you make these repairs.
Microwave timer works, light works, but heating mechanism will not engage-- no "sound" or "heating" when I hit start (although the timer mechanism sets & counts down, even when...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Our microwave is not heating and the turntable is also not working. When I try to cook something the timer starts counting down but nothing else happens.
Basic
heatman101
1helpful
2answers
Kenmore Microwave stopped working.Mod# 87103
To the guest who wrote:
Aug 15, 2008- Won't run on start. the minute number flashes and same with the word TIMER on the top right.
Clock will change but won't start..
Did you ever solve this problem? I have the same one as of yesterday... this is a fairly new microwave, would hate to have to replace it so soon.
1helpful
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
2answers
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
