There is a large slotted screw in the center of the flush valve. Use the biggest straight bladed screwdriver you have with nice sharp edges to loosen if not remove screw. Once you get it loose at least you will be able to tilt it out at an angle. that's how I got mine out. now all I have to do is find a new one!!!
It's been a little over three years since I bought a new one @ a local independent plumbing supply. I spent around $70.00 for the darn thing. The flapper lasted about 2 1/2 years here in Florida with a mix of both Clorinated and Brominated water. I gave the sealing surface a light stoning with a medium fine 6" stone. I just changed out the Fill valve assy with the second "Cheapy" from Home depot. Wish I could find a better one. Otherwise the "Old Eljer that could" is working great!
