2003 Dodge Durango Logo
Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 Durango, Truck 5.9, Car is intermittently having trouble shifting from 1 - 2nd - reves to ~3 RPM, then lunges into the next gear. I've been doing my homework on the net, but can only find info on non 2003. Any insite?
William Robinson
Level 3:
Genius:
  • Master 1,547 Answers
  • Posted on Dec 11, 2010
William Robinson
Master
Level 3:
Genius:
Answers
1547
Questions
0
Helped
501974
Points
4729
Possible Cause
The following items may be area of concern:
?¬Other transmission-related DTCs are set.
?¬Solenoid pack connector 5-volt supply circuit open.
?¬Sensor signal circuit has short to ground, short to voltage or open.
?¬Governor pressure sensor defective.
?¬Transmission fluid burnt or oil pan contains excessive debris.
?¬Governor pressure out of range.
?¬Transmission leaking internally.
?¬Defective PCM.
?¬Defective valve body.
Diagnostic Procedure
1.Using scan tool, read DTCs. If good trip counter for DTC P1756 is not displayed or displayed count is not zero, go to step 25. If good trip counter is displayed and displayed count is zero, go to next step.
2.Repair any other transmission-related DTCs before proceeding. If no other transmission-related DTCs exist, go to next step.
3.Check transmission fluid for proper level and for any debris. Fill or repair transmission as necessary. If fluid level and condition are okay, go to next step.
4.Start engine. Allow engine to reach normal operating temperature. Set parking brake, depress brake pedal and place gearshift lever in "D" position. Using scan tool, observe governor pressure sensor pressure. If pressure is greater than 3 psi (.2 kg/cm 2 ), go to next step. If pressure is 3 psi (.2 kg/cm 2 ) or less, go to step 20.
5.Turn ignition off. Install a pressure gauge at transmission governor pressure test port. Start engine. With gearshift lever in "D" position, observe gauge pressure. If pressure is 5 psi (.3 kg/cm 2 ) or more, go to step 23. If pressure is less than 5 psi (.3 kg/cm 2 ), go to next step.
6.Turn ignition off. Disconnect transmission solenoid assembly connector. Turn ignition on. Measure voltage between ground and 5-volt supply circuit at transmission solenoid harness connector terminal No. 2. If voltage is 4.5-5.5 volts, go to next step. If voltage is not 4.5-5.5 volts, go to step 19.
7.Turn ignition off. Disconnect PCM harness connector C2 (White). Measure resistance of governor pressure sensor signal circuit between transmission solenoid harness connector terminal No. 4 and PCM harness connector C2 (White) terminal No. 29. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair governor pressure sensor signal circuit for open.
8.Disconnect PCM harness connector C1 (Black). Measure resistance of sensor ground circuit between transmission solenoid harness connector terminal No. 3 and PCM harness connector C1 (Black) terminal No. 4. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair sensor ground circuit for open.
9.Measure resistance of governor pressure sensor signal circuit between ground and transmission solenoid harness connector terminal No. 4. If resistance is less than 5 ohms, repair signal circuit for short to ground. If resistance is 5 ohms or more, go to next step.
10.Measure resistance between sensor signal circuit and sensor ground circuit at transmission solenoid harness connector terminals No. 3 and 4. If resistance is less than 5 ohms, repair governor pressure sensor circuit for short to sensor ground circuit. If resistance is 5 ohms or more, go to next step.
11.Turn ignition on. Measure voltage of governor pressure sensor signal circuit between ground and transmission solenoid assembly connector terminal No. 4. If voltage is one volt or less, go to next step. If voltage is more than one volt, repair sensor signal circuit for short to voltage.
12.Turn ignition off. Ensure transmission solenoid harness connector is disconnected. Remove transmission oil pan. Disconnect governor pressure/temperature sensor harness connector. Inspect connector and terminals for damage. Repair as necessary. Measure resistance of governor pressure sensor 5-volt supply circuit between governor pressure/temperature sensor harness connector terminal "A" and transmission solenoid harness connector terminal No. 2. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
13.Measure resistance of sensor ground circuit between governor pressure/temperature sensor harness connector terminal "D" and transmission solenoid harness connector terminal No. 3. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
14.Measure resistance of governor pressure sensor signal circuit between governor pressure/temperature sensor harness connector terminal "B" and transmission solenoid harness connector terminal No. 4. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, replace transmission solenoid assembly (internal transmission harness).
15.Measure resistance of governor pressure sensor signal circuit between ground and governor pressure/temperature sensor harness connector terminal "B". If resistance is less than 5 ohms, replace transmission solenoid assembly (internal transmission harness). If resistance is 5 ohms or more, go to next step.
16.Measure resistance between governor pressure sensor signal circuit and sensor ground circuit at governor pressure/temperature sensor harness connector terminals "B" and "D". If resistance is less than 5 ohms, replace transmission solenoid assembly (internal transmission harness). If resistance is 5 ohms or more, go to next step.
17.Reconnect transmission solenoid assembly harness connector. Turn ignition on. Measure voltage of governor pressure sensor signal circuit between ground and governor pressure/temperature sensor harness connector terminal "B". If voltage is more than one volt, replace transmission solenoid assembly (internal transmission harness). If voltage is one volt or less, go to next step.
18.Turn ignition off. Using DVOM, backprobe governor pressure sensor signal circuit at PCM harness connector C2 (White) terminal No. 29. Start and idle engine. Place gearshift lever in "N" position. Using scan tool, observe governor pressure sensor voltage. Compare scan tool value with DVOM voltage. If voltages match, replace governor pressure/temperature sensor. If voltages do not match, replace PCM.
19.Turn ignition off. Ensure transmission solenoid harness connector is disconnected. Disconnect PCM harness connector C2 (White). Measure resistance of 5-volt supply circuit between transmission solenoid harness connector terminal No. 2 and PCM harness connector C2 (White) terminal No. 31. If resistance is less than 5 ohms, replace PCM. If resistance is 5 ohms or more, repair 5-volt supply circuit for open.
NOTE: Removing transmission control relay in the following step may set other DTCs. Disregard these DTCs.
  • William Robinson
    William Robinson Dec 11, 2010
    20.Ensure engine is at normal operating temperature. Place gearshift lever in
2answers
At a stop the jeep want to shift or lunge forward
If it is dropping out of gear and back in at stops, this could just be low fluid. If the fluid is good, look at cleaning the inside of the throttle body, to include the back of the throttle valve. Build up clings here and air restriction can cause the IAC motor to do funny things.
2answers
Transmisson wont shift from second to third
you may try reving engine alittle higher try shifting to fourth if that works your third gear sincroniser is shot
Lunges in upper gears
lunges?
well is then surging,? (rpm)
or is the transmission just slipping, or shifting wrong.
only you an tell this. not us.
like a standard, you mean manual stick shift??
but you never said what trans is there. auto or stick? so?
8helpful
2answers
Code po734, po735
This is what your codes mean:
Trouble Code-P0734 (A/T Additional Gear Ratio Error In Fourth Gear)
Trouble Code Conditions:
Vehicle driven to a speed of 4-37 mph at more than 500 rpm, gear selector in 4th Gear in Drive, and the PCM detected too much difference in the engine speed and output shaft speed.
Possible Causes:
  • Customer may complain of intermittent 4th gear operation
  • O/D and 2/4 pressures less than 75 psi
  • O/D or 2/4 clutch volume indexes out of specification
  • O/D accumulator seals are damaged
  • Transmission enters "limp in" mode running in 4th gear
Trouble Code-P0735 (A/T Gear Ratio Error Fourth Prime)
Vehicle driven any forward Gear, and the TCM detected the ratio of the Input speed to the Output Speed did not match the current Gear Ratio (this test can take up to 5 minutes).
Possible Causes:
  • Related Gear Ratio trouble codes may be stored (note that some of these Gear Ratio trouble codes may be intermittent)
  • Transmission has internal problems or damage present
You have a transmission problem.
RPM guage barely moves when revved/Will not shift gears.
It sound like your transmission linkage needs to be adjusted.
Its hard to tell what is wrong with the tachometer, without knowing if it is original, an aftermarket, or if anyone has messed with the wiring.
I would suggest buying a repair manual (Haynes is about the best).
My transmisson makes a weezing sound when im at low speed
You sure its the transmission? Wheezing sound is usually the catylitic converter becoming plugged. Also...at 3-5K rpm you are not idling, you are reving the engine...(in that case, trans may be slipping or flairing between shifts, unless the unit is staying in one gear and just delaying shift till you reach that rpm. actual shift point should be close to 2,000rpm) I'd check the cat first.
5helpful
2answers
2004 Impala - 115,000 miles - has intermittent hard shifts
The dealer should know this! The EPC solenoid (controls pressure) hangs up with wear and causes the harsh shifts.
1999 Dodge Durango gears not shifting
This website www.reliable-store.com has the
largest collection of repair, service,
parts manuals of any vehicle on earth. Best website I came accross for manuals.. Very helpful website
Auto Transmission 2000 Rodeo
It seems that the trans is slipping. The smell is from excess trans flood. If Trans is over filled, it can rupture seals and cause leaking that can get on the exhaust and burn.
1helpful
Shift into gear
Ok if this is going on 9 out of 10 times it is from the switch from your brake deppresion sen- under the dash. comman problem with these models.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
