Question about Pentax ZX-50 35mm SLR Camera
The shutter on my Pentax zx-50 SLR is stuck in the open postion. I can't see anything through the view finder nor will it focus automatically. However, it will advance the film upon taking a snapshot and the built-in flash works.What is my problem? Thank you
  • mikelennie Nov 30, 2010
    I was hoping that we didn't come to the same conclusion.Thank you just the same.I really appreciate it.
    President:
  • 2,702 Answers
If its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Posted on Nov 28, 2010
  • mikelennie Nov 29, 2010
    The shutter is in the up position but when I push it down it goes right back up.
  • Michael Thorpe
    Michael Thorpe Nov 29, 2010
    then if i were you i would have the camera serviced,,,,this is not a job that you yourself can fix easy
6ya staff
SOURCE:
Lens zx 30
is the mirror stuck up? Lots of these ZX Pentax models have failure of the mirror motors when the plastic gear on the shaft of the motor cracks and then the motor just runs continously
Oct 20, 2013 | Pentax ZX-30 35mm SLR Camera
Can't see through the view finder. Camera is on and Lens is automatically attempting to focus. I cannot see through the view finder and the camera will not take the shot.
Take off lens. Is mirror up or down? If mirror is stuck up motor or shutter failure. Is the shutter open (can you see the image sensor?). Was the camera impacted?
Oct 18, 2013 | Nikon D70s Digital Camera
Can't see anything through the view finder, i've
The mirror in the lens throat has locked in the up position. Mirror lockup can usually be cured by replacing the batteries.
May 10, 2010 | Pentax ZX-7 QD 35mm SLR Camera
Can't see anything through the view finder, i've tried reloading the lens but still nothing
You have mirror lock up. The most common cause is dead batteries so try replacing them.
Mar 18, 2010 | Pentax ZX-7 QD 35mm SLR Camera
Shutter locks up and won't release (zx-10)
Its gonna need repair. Most likely causes:
Lubrication dried up/deteriorated internally
Shutter electromagnets need repair/ clean/ replace.
(This was a constant issue with the Canon T-90)
Shutter blades out of alignment
Shutter speed stuck on B (not likely)
Oct 13, 2009 | Pentax ZX-10 35mm SLR Camera
Pentax MZ50/ZX50 - no photo when shutter is pressed
first make sure the mirror is fully down. if down
take your MZ50 to a camera store and try a different lens. if it does the same thing then your camera needs repaired. flex circuit,
if the different lens works then the lens needs repaired.
Jul 20, 2009 | Pentax ZX-50 35mm SLR Camera
Zx-7 shuter wont trip
This sounds like a broken drive pinon on the motor. (They made these out of plastic to save weight.)
If so (and it is very common) The only solution is a new motor I'm afraid, and this makes for an expensive repair, if the motor can be obtained. (Which is unlikely.)
Sorry.
On the bright side, Pentax have a great reputation for compatiability throughout the range. So the lens is worth keeping. Just obtain another pentax body.
Jan 18, 2009 | Pentax ZX-7 QD 35mm SLR Camera
Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Sep 03, 2007 | Pentax ZX-50 35mm SLR Camera
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Aug 31, 2007 | Pentax ZX-7 35mm SLR Camera
Pentax ZX-50 35mm SLR Camera Logo
637 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
