Televison & Video Logo
Posted on Nov 27, 2010
I have a asus m4a88t-m motherboard that supports hdmi. When I hook up the hdmi from computer to tv. the tv does not see it even it is on hdmi 2. Is there something in the motherboard that I need to change
2 Related Answers
Anonymous
  • 3741 Answers
  • Posted on Nov 16, 2009
SOURCE: I have a 37" Insignia
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
A
Anonymous
  • Posted on May 31, 2010
SOURCE: TV says it does not support HDCP.
UNPLUG ALL CONNECTION FROM DECODER EXCEPT MAIN CABLE SIGNAL UNPLUG POWER WITH CABLE ONLY CONNECTED RECONNECT POWER WAIT FOR CLOCK TO DISPLAY HDCP SHOULD BE GONE RECONNECT ALL OTHER CABLES
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
M4a88T HDMI port does not work
Is the TV turned on and set to the input that you have the HDMI cable connected to?
Have you tried other HDMI ports on the TV?
Have you tried it with another HDMI cable?
Have you tried it with another TV?
Just powering on my new ASUS M4A88T-V EVO Motherboard to check if I have my connections done right, Receiving two short beeps then no beeps, Trying to find out what that means
2 Beeps? maybe Parity circuit failure
it is responsible for generating and checking the parity bit on the system memory when parity checking is used. This circuitry is not working properly.
This code usually means a problem with either the system memory or the motherboard.
Try to reset the cmos remove the battery. if not check the memory,try clean the gold surface of the memory using pencil eraser.
Hooked everything up all new components, everything meets specs, computer will not boot. M4A88T-V EVO/USB3 motherboard.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
I have an asus m4a88t-v motherboard with an AMD phenom II x6 1090T processor that I just built. When I turn it on, it powers up but nothing shows up on the display. There are no beeps from the motherboard...
make sure the battery in mother is good and double check fuse. what it is you have a 3x2gb corsair is over loading your mhz ram get a higher battery for higher performance and see what happpens.
2answers
My system is hooked up correctly. i have all the wires in the right place. my screen doesn't acknowledge the mobo or gfx card.us all parts compatable everything snapped into place.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
1helpful
2answers
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
