SOURCE: JVC THD-50 system
Yes, that is correct. You can either use optical or digital for the audio to the jvc system. They give you 2 options but you can use either, they both work just as well.
SOURCE: home theater
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
SOURCE: can i hook my laptop to JVC THD-50
yes its posibble. you need to use a 3.5 mini plug(like your regular headphone connection) to red and white composite(male plugs) cable to connect to back of th-d50.
