Does this unit have an OXYGEN DEPLETION SENSOR ? if so, then are you using the heater in an area that is too confined or too closed-up? You say it is forced air, therefore the air must move continuously or the over-heat sensor will stop the gas since there is no air to remove the heat being produced. If this unit has a thermocouple flame sensor, the flame my not be touching thethermocouple sufficiently and the thermocouple thinks something is wrong and stops the gas. Or the thermocouple can be weak and not give a strong signal to allow the gas valve to stay open. This is common on heater and hot water heaters, and you simply change the thermocouple.
Good Luck, Macgivor
