SOURCE: Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently. Means the machine is locked, for children. I think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks
think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault. However, it is also caused by spikes in the mains and can be spurious. To reset it. Turn the appliance knob to the off or reset position, 12 o'clock. Turn the knob to the 6 o'clock position. Press and hold the spin button. While holding it, turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds. Release the button. Turn the knob to off. When your turn it back on it should have cleared the error code
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Release the button.
If the problem continues then check the motor...
heatman101
To reset it.
Release the button.
To reset it.
Release the button.
