Probably solenoid water valves at the bottom inlet water area.
Check that they "click" when activated. Also could, but unlikely to be filter.
Water circuit is to filter first then to ice/water as needed.
Both ice/water solenoids have failed, but may be main solenoid valve. I would check that one first.
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
SOURCE: kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
