Have 2 hp cmptrs. one has bad hard dr no recovery disks. can i switch it out to one that does and run recovery to fix it?
You can put the defective HDD in a computer thats running correctly and use the existing OS to gain access to it. That way you can extract all the info from it. Do not remove the main HDD, simply shut down the PC, open it, add the Hard Disk Drive to the MOBO and restart. you may get an option to decide which HDD you want to boot from, make sure you boot from the good one.
Make a file and extract all info.
If the new computer does not recognize the drive, there are steps you can take to find it.
I've done this hundreds of times and have had around 87% success.
Unfortunately, some HDD's are destroyed and no data can be extracted.
Good Luck
No the recovery is in the bad hd. now if u wana try to recover some of the data u can try ubcd4win.com to create a bootable cd with usb support for thumbdrive or put both drives on same pc and try.. but no cant do it that way.. close but not quite.
the pc has xp sticker on side of xp home ?
Hope this helps
Hope this helps
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware
System Utilities which includes data recovery software, data backup, password
reset tools for Windows helps you to maintain your system. Dr.Freeware is
freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS,
FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB
Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB
Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista
/ 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file
system is damaged, has lots of bad data blocks)
Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local)
account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Support IDE/SATA/USB Hard Drives hope it helps
Hope this helps
Hope this helps
