Most likely you have a bad bake ignitor part number WB13K21 and it's around 80 dollars,unplug the machine or shut down the breaker,remove the racks,remove the bottom floor of the oven,remove the flame panel and you'll see the ignitor attached to the burner tube,unplug the wire harness going to the ignitor,remove the screws holding the ignitor in place,plug in the new ignitor and put the screws back in,turn the power on and put it on bake,the ignitor should start to glow and the flame should lite in around 40 seconds.there are other ignitors that you can use in the stove,the only difference is that you cut the wires going to the old ignitor and splice in the new ignitor and use ceramic wire nuts to connect the wires together,it just doesn't have the harness connector on it
