Sony Playstation 3 (PS3) Console Logo
Posted on Jun 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Hi, it would be marvelous to sit back and play challenges online with my new PS3 console :D
Although ... with help from my ISP (AOL) with the connection details i need it still doesn't work! When going through the settings manually the console recognises my IP address but not the DNS. When contacting AOL with the info they gave me i'm only given one DNS code or (DNS Server) from my comp? Which could be why its not connecting?
When trying automatic for the console to recognise the server itself, neither options IP or DNS work but misrably fail.
I've read on reviews i may need to change my firewall settings, but i think the DNS needs to be correct first from what the PS3 Internet Connections Settings say.
Any help would be much appreciated, i will work for food ! I`m having the same problem. Very frustrating :(
  • 4 more comments
  • Anonymous Jun 24, 2008
    get
  • dutyofcall Jul 12, 2008
    ok so i got a ps3 today and i try to go online and it recongizes my ip adress but not my dns server
  • jamsoaker Sep 21, 2008
    hi im trying to connect my ps3 to the net through my laptop connection port, its running windows vista, ive allowed interconnection sharing and all that but it still says ip sucseeded and dns failed, i tryed enter it manually and everthing. been trying for weeks now. help
  • Anonymous Sep 24, 2008
    it really takes the **** the japs an the comys haha make everythin worse haha oj i luv thr japs realy
  • nozbo Feb 18, 2009
    try to play zombies on code5 multiplayer,error time out all the time
  • danbrolive Apr 11, 2009
    i have a laptop which i use the t stick in the usb port 4 mobile internet its great but i cant seem to plug it into the ps3, got a network cable now and the ps3 picks up the lappy but even tho its already online and plugged into th usb network port its sadly still not going online :( any help or ideas from anyone would be greatfully put to quick use
clark styx valencia
Level 2:
  • Expert 282 Answers
  • Posted on Jun 24, 2008
clark styx valencia
Expert
Level 2:
Answers
282
Questions
0
Helped
130221
Points
829
Try this
So what I found out was to put in the IP address you find in ipconfig/all but add one to the last octive. Example if yours is 172.16.1.25... then in your ps3 type in 172.16.1.26
Then I was using the primary and secondary DNS numbers that my computer was giving me in ipconfig/all. Do not use those. For your primary DNS number use the number for your default which should be a right below your subnet mask number. For the secondary DNS number just leave it blank. 0.0.0.0
Then you have to upgrade to version 1.50 (which just came out yesterday actually). Get a memory stick with at least 100mb space on it. Make a new folder that is names PS3. Inside that folder make another new one that is called UPDATE. Both must be in capitol letters. Then go to PlayStation.com - PLAYSTATION®3 - Network - updates and click on "download now"... Then click save and save it to your memory stick in the UPDATE file, which should be in your PS3 file.
Then after all is done... plug that into your ps3 in one of the USB ports for the controllers. In the main screen go to SETTINGS and then go to SYSTEM UPDATE. Go to UPDATE VIA STORAGE MEDIA. PS3 will search for your media stick and it should say on the screen The latest update data was found... Version 1.50. Click OK and follow the rest of the instructions. After it is completely done... go back to the internet connection setup and go through all the menus to make sure all your numbers are the same as I stated above. Then at the end run the connection test. It should work!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1286
Points
I have the same shitty problem the only reason i got ps3 was for free live and now it doesnt work, it only takes the IP adress, and not the Primary or SEcondary DNS
2 Related Answers
Anonymous
  • Posted on Aug 09, 2008
SOURCE: PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
for mine i tried other fixes and they didn't work. Turns our my router had enabled security but the PS3 had forgotten the password (WEP key).
I turned off the WEP on my router and the PS3 suddenly found its connection.
To say I was getting stressed is an understatement, Sony should put something on their website, it seems like a really commonm problem to which people have no clear route to solution.
Anonymous
  • Posted on Feb 05, 2010
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
2answers
DNS error 80710102
I had this problem a while back, turned out it was a loose connection to my router. This is also displayed when the broadband connection is down. Normally if you give it a while it will work, if not try resetting your broadband and router by unplugging them from the mains for 5 mins.
Getting dns error 80710102
The "DNS error 80710102" is an error displayed on the Sony Playstation when attempting to connect to the Internet. It's a known problem for Playstation users, but the answer is to disable universal plug-n-play on the router.
Thank you !!
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
Dns server error code 80710102 continually when trying to sign in to PSN. Spoken to router manufacturer Belkin- opened ports
2helpful
3answers
DNS ERROR 80710102 DIFFRENT PROBLEM
I have had this same problem do you have verizion if you do then simply change it to myfairpoint.net do system update and change it there then if it still does not work try adding a wired connection hope this helps :-{D
Dns error 80710102
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
2helpful
3answers
PS3 Error Code 80710102
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
310helpful
41answers
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
