SOURCE: HP F380 printer
This happens when your print head gets dirty. Just claening the print head should solve your problem. To do this: Click start button > click Printers and faxes. > Right the printer icon > click properties > Here you should find something like "Head cleaning" or "Clean the print head". This option can be used to clean the priter head automatically. If it does not work, you can manualy take out the cartridge and dip it in to IPA (Isopropyle alcohol) solution would clean the head[dip the head only not the complete cartridge]. After a few minutes (10-20) you can fit the dry cartridge the printer. If nothing works try changing the cartridges. Note: When the ink is running out this may occur. The only thing we can do is to replace the cartridge.
SOURCE: hp laserjet 3330 printer printing junk characters
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
