Question about Kenwood KDC-215S CD Player
Hi there i would like to know or see a diagram of the wiring harness for a kdc-215s cuz i need to make a harness by myselft i just have the unit with out harness. I just know that its 16 pins but i need to see which wire go to each pin....like for example which one is power ground and speaker and etc. Thanks ill appreciate
6ya staff
SOURCE:
simplemitch
Mitch
  • 752 Answers
SOURCE: Kenwood cd kdc 215s
Contact a stereo shop. they should be able to get you an adapter that will interface it with the amp.
Posted on Sep 15, 2007
Anonymous
  • 1067 Answers
SOURCE: kenwood kdc mp-425 plug
i have kenwood wire book i can tell u colers ?
Posted on Jan 21, 2008
Tim Swiercinsky
  • 1126 Answers
SOURCE: sterio/cd player has a 24 pin, and a 12 pin input.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967688DEHP2900MPInstallationManual1027.pdf
Look on page 2 for color coding.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
I don't see an actual pin out diagram. I believe that Walmart sells an adapter harness for Pioneer instalations.
Posted on Sep 11, 2009
Rob C
  • 547 Answers
SOURCE: Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
Posted on Oct 02, 2009
kenw392
kenw392
  • 2226 Answers
SOURCE: does the kenwood kdc-215s stereo play mp3s?
probably not
Posted on Nov 12, 2009
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I need to know which wires go to which on a 2000
Kenwood wiring diagrams are usually on Kenwood website. You just need a jumper harness from the Toyota plugs to your player. A good local ICE shop or car accessories shop could help. Try EBAY?
Oct 20, 2014 | Cars & Trucks
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Oct 17, 2011 | Kenwood KDC-138 FM / AM Receiver
KDC-215S battery drain
You could add a switch to control the power going to the head unit. I have seen this done in many different vehicles where the head unit drains the battery, even when supposedly off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Kenwood KDC-215S CD Player
Wiring to power it up
without wiring diagram i can tellyou what you need to know. start with the red wire it is your switched power wire meaning when your key switch is on you will havee power when the key switch is off you will not have power. Next wire is you yellow wire which is memory it is a constant power wire meaning it should have power all the time key on and key off. next is the black wire which is the chassis ground. Now you should have a set of green wires and a set of purple wires these are your front speakers left and right. next you should have a set of grey wires and a set of white wires they are your rear speaker wires left and right. subwoofers hook up through the rca connectios which are the red and white circles on the back of the radio red is right and white is left. ps. no bare wires touch metal when power is on. good luck
Apr 23, 2010 | Kenwood KDC-215S CD Player
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Kdc 215s
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
May 07, 2008 | Kenwood KDC-215S CD Player
Kenwood cd kdc 215s
Sep 13, 2007 | Kenwood KDC-215S CD Player
Kenwood KDC-215S
mechanism out of siychrony.....you need a nearest technical support.
Mar 12, 2007 | Kenwood KDC-215S CD Player
Kenwood KDC-215S CD Player Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
