SOURCE: RCA L32HD31 32in TV - out after 18 months
Unplug your set for about 2 minutes... and try to "reboot it' This seems to be VERY common on these RCA LCD sets. I do NOT know what "locks up", but if the set is dead and you get a "putt" noise from the speakers every few seconds...this IS the problem. Try it--I have "fixed" a LOT of these sets this way.
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
SOURCE: WON'T TURN ON
Ur controller board it dead,the one in the middle bottom of LCD screen.It a small square board.Replaced this board should have sound and picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Controller board for the replacement.
SOURCE: I am having issues with my RCA L46wd22yx5. First
Check to make sure that the individual cables are connected to the corresponding channel. For example, DVD player is connected to the "Video 1" output on TV. On the back of your DVD, the cable is plugged in the "out" output, going to your TV the cable is plugged in the "in" output(red, white, yellow) Are you using an RCA cable(red, white, yellow) for the units?
SOURCE: rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
