Hampton Technologies Brinks Timer Logo
ROBERT E MITCHELL Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15- MINUTE TRIP SETTINGS, 15-AMPERE, 120-VOLTS.
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Nov 27, 2010
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10843791
Points
101584
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
1helpful
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
How do you use a brinks mechanical timer 42-1020? I have figured out what all parts are just don't understand how to use the pins??
Brinks 42-1020 is analog timer with 48 segments (pins) located around edge of dial.
Each segment (pin) represents 15 minutes in 24 hour day.
Segments on this timer push down and outward.
Open following links for instruction illustrations:
http://waterheatertimer.org/pdf/Brinks-42-1020-manual.pdf
http://waterheatertimer.org/How-to-set-timers.html
I have intermatic TN311 MODEL TIMER IDK HOW 2 WORK I WANT IT TO COME ON AND OFF FOR 15 MIN EVERY HOUR FOR 12 ORS A DAY IS THAT POSSIBLE AND HOW
Open following link to identify TM311 timer:
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
1) First of all, you would need more turquoise 107TN222 ON and red 107TN221 OFF trippers.
2) BUT big problem is that TN311 time dial is divided into half-hour segments, so minimum on-off is probably 1 hour since it takes 2 trippers for on-off cycle, and width of 2 trippers is same width as 1 hour.
3) Open following link for plug-in timers with 15 minute segments shows Woods 49664 & Stanley 31192 & Sylvania SA110
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
4) Notice the 49664 dial, that each hour is represented by 4 segments. This says timer on-off period is 15 minutes.
To set this timer, you would pull up all segments around the dial, and then push down 1 segment for each hour that you want timer to turn on for 15 minutes.
5) TN311 has 3 prong grounded outlet, Woods 49664 has 2-prong outlet.
6) Stanley 31192 timer and Sylvania SA110 have 3-prong grounded outlets and 15 minute intervals.
7) You cannot accomplish 15 minutes intervals for 12 periods a day with programmable digital timer.
Most digital timers allow 1 minute program times, but are limited to 6 or 7 programs, and not the 12 separate on-off periods needed for your project.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
3helpful
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Manual appears on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
How do you set the timer in fifteen min. intervals? Especially when there are 4 pegs?
1) You need a timer that breaks 24-hour day into 15 minute intervals.
Hampton timer and other timers with movable trippers cannot be set for 15 minute intervals.
2) All mechanical plug-in dial-type timers have 1/2 hour intervals or more
a) For example Woods 59366: sold at Lowes as Utilitec 0148297 or Target as Westek TM series
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
b) Or GE 52012 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#52012
3) If you want 15 minute intervals, you need digital timer.
a) For example GE 15091 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
b) Woods 59377 sold at Lowes as Utilitec 015671 or Target as TE06
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
4helpful
2answers
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
120 volts 50 hz
hi the Electrical Requirements of this device: 15 OR 20 Ampere, 120 Volts, 60 Hertz (1/second). go to elctronics shop with these details and buy a transformer wich will translate your current Volt\ampere\frequency to what the device needs wich from what i understand needs higher frequency http://www.whirlpool.com/catalog/product.jsp?parentCategoryId=113&categoryId=115&subCategoryId=116&productId=218&view=2#tabs good luck
Top Hampton Technologies Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
