LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It just stopped cooling. It was making a humming noise for about 2 weeks and by mid afternoon on Thanksgiving day - it just stopped cooling.
Anonymous
Level 3:
  • Master 348 Answers
  • Posted on Nov 26, 2010
Anonymous
Master
Level 3:
Answers
348
Questions
7
Helped
99456
Points
1063
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
In what month and year is Mad Men set?
Season 1 opens in March 1960 and finishes Thanksgiving Day, 24th November 1960. Season 2 picks up on Valentine's Day, 14th February 1962 and ends in October 1962 with the peaceful resolution of the Cuban missile crisis. Season 3 starts somewhere during Spring 1963 with Betty Draper (January Jones) being approximately six months pregnant and ends on the evening of 16th December 1963. Season 4 begins around Thanksgiving in November 1964 and ends in October 1965. Season 5 begins on Memorial Day weekend in May 1966 and ends in March 1967. Season 6 begins at Christmastime in December 1967 and ends on Thanksgiving Day, 28th November 1968. Season 7 begins in January 1969, around the inauguration of President Richard Nixon and ends mid-season on the morning of 22nd July 1969, two days after the successful moon landing of Apollo 11.
1helpful
Why did a hum/buzz sound come from mid to back area after being turned off couple hours?
Hi: If you just bought the car there should be some kind of recourse with the dealer, There are lemon laws to protect the buyer. Check it out. It could be the fuel pump losing it's prime and the hum you hear could be the pump going on to restore it's prime. Good Luck
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
