There are various steps to fix this issue.
Step 1.
For Vista and Win 7 PC
1.Go to Control Panel - Power Options
2.On the Left side there is a column - " Click Change when the computer sleeps
3.Click the drop-down box which says Put the computer to sleep and select 'Never' for both battery and 'plugged in'
4.Click 'Save changes'
For Windows XP
1. Go to Start - Control Panel - Power Options
2. Under the Power Schemes Tab, set the Standby and/or Hibernate Options to 'Never'.
3. Click Apply/Ok and you're done.
Step 2
1. Right click on the desktop and click Properties.
2. Click Screen Saver + below you will find Power Click on that
3. You will see Settings for Home/Office Desk power scheme and in Turn off Monitor slect Never and click Apply.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
SOURCE: Monitor
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t139319-monitor
SOURCE: Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
SOURCE: my LCD monitor is going into power saving mode
nothing to do with your back light.
PLEASE try another VGA cable
I say get a new vga cable and your troubles will be over,had the same problem with a dell lcd and a lg lcd new cable worked on both ! I know, how does a cable fail , who knows ? must of been a bad batch or something silly went on !
